shift cables
TC Mueller
169
Jun 23, 2006
Bartlett, Illinois
so after the install of my transmision and all that good stuff. i let the car idle for a little bit pump the clutch a few times (that new 2600 feels really nice) i go and attempt to put it in first gear and i feel the shifter just slide up with no engagement. it felt like if you were to take a braided peice of wire and rub on the edge of a table. thats what i felt in my shifter. so i took a look and i believe it was my select cable that the boot after the washer ripped and the cable was exposed. the cheapest i found the wires was mach v for 132 does anyone know any other place i can get cables for a 92 talon tsi awd?
Try the classifieds, hit up a junkyard, or look around on ebay. I picked mine up for about $50 shipped, if I remember correctly. Keep in mind that any year 91-94 will work on your car (but not 1990!).
:thumb:
Edit: If you'd prefer new ones, you can try San Rafael Mitsubishi. Mention you are a DSM Tuners member to get a discount. Not sure what they run new, but might be worth giving them a call.
I had to replace mine as well, I went to the local Mits dealer and bought new ones. Honestly its been over a year now so I cant remember the cost on them. I'd go with OEM though on those parts if I was you.
JNZ Tuning
http://jnztuning.com/
(215) 997-6850
Straight up!
JNZ will be the cheapest place for Brand New Mitsu parts!
I needed new cables for my 2G, every where they where like 130, JNZ had them for 75! JNZ carries all OEM Mitsu parts. I recommend all DSMers go to them for price check on any factory parts. They also have Aftermarket parts.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
