Shift cables
Dream On
2,242
23
Sep 6, 2003
Athens/Oxford, Ohio
Would it mess up the shift cables if someone shifted your car when they were disconnected from the transmission? This happened some time ago when I was doing a clutch job, and I've been having problems getting the car to disengage since I put the clutch in. Just curious if this could be part of my problem. Thanks.
It won't make any difference - the cables move the same connected or disconnected. What kind of clutch did you put in?
Dream On said:
Spec Stage 3. Thanks.
Have you verified the clutch engages 100%? Can you shift gears easily with the car turned off? I'd adjust my clutch pedal, bleed my lines, and verify properly slave cylinder operation before going any further.
I can shift when the car is off, I've adjusted the pedal, bled the lines, and replaced both the slave and master cylinder as well.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
