shift cable
awdturbo-g1
70
Apr 4, 2010
st.peters, Missouri
does any one know how to fix the shift cable it broke by the trany and now its hard to fet in all the bottom gears when i was raceing, the cable came undone? if any one has an idea let me know thanks
yeah it came off. the part on the trany is on and its still on the leavers on the trany, were it bolts to the trany there is a rod that the cable runs in to and thats what borrke or came off
OK if it just came of then slip the circular end back over the lever on the transmission. It is held in place with a very small cotter pin. If it is actually broken then you are going to have to replace it but I would get a used one because these things don't usually go bad and the new one is pretty pricey. If you are still having problems then post a picture so we can see exactly what is going on.
Hope this helps!
make sure you get one as the same year as your car cause I know that some of the years are different cables
