Shepherd Clutch Pedal Bushings
U8NTRDY
137
Oct 12, 2010
philadelphia, Pennsylvania
Anyone have any experience or feedback on these? Worth the 35 bucks?
Yes. Oh my jeez, yes. Check your brake pedal at rested position in relation to your clutch pedals height. Compare the two. If theu clutch pedal appears ANY lower than the brake pedal while they are in rested position, then your bushings are worn and YOU NEED THIS KIT. If you either have a better clutch or over 100k miles, then chances are You need this kit.
i recommend you get shep to do it for you for 125$. Its worth it, they weld it and change pads. The removal of the pedal assembly isnt fun but there are many forums online to help you through with pics etc.
Ok I will def look into this. Thanks for the input!
* Just because the pedal is low it does not mean the bushings are worn. Adjustments of the top switches can cause one pedal to look lower than the other.
They are worth it in the end. I had Shep do mine and a couple months down the road my pedal assembly went back to the same routine. I contacted Shep and he said if I was to ship it in he would have another look at it. Once he got it one of the welds cracked causing the pedal to be low again. He fixed it for free and shipped it to me for free. I haven't had trouble since.
we have did this to a few 1gs and also welded the petal to the assemble it removes play and the petal wear feeling, also have found it that it elimates one of the clutch disingaugment problems, but the petal overall feels alot smoother and better.But like said already it is a pain to remove.
Well the thread was about shep bushings so i linked you to his site. If he makes them for a 2g they will be on the site.
