samwiseg27
- 0
- Nov 21, 2011
Escondido,
California
Hi, Im a newbie to this site and a newbie to dsm's altogether but I'm slowly learning a lot more about them.
I have a shaking problem with my 1997 2G converted to a GSX from a GST, 6 bolt swap.
It runs fine when you first start it and drive it for a few minutes, but then all of a sudden it will start shaking when you put your foot on the gas. When you release the gas pedal, the car is fine. It will only have violent shaking as you step on the throttle and it doesn't want to pick up speed. Idk whats going on, but I've already tried a couple of things that haven't worked. There are no boost leaks, i put in a new bosch o2 sensor, put in new ngk bpr6-es plugs. The engine is all stock with a 14b turbo. Again, 6bolt swap engine, 2g tranny. The only thing i can think of that could be the problem is the ecu. Will i have to reprogram it? Please let me know what you think, again i am a newbie so please be patient with me.
-Thanks
-Thanks
.... harmonic balancer???
