setup???
WRX19
61
Nov 15, 2003
Seattle, Washington
What do you guys think of this setup on a 91 Talon TSi AWD
JDM Evo Short Gear Tranny
ACT 2100lb Clutch
ACT Streetlite Flywheel
2" Drag Springs with KYB Shocks
Konig Rims
Buschur Turbo-back exhaust (downpipe, test pipe, catback)
Big 16G Turbo
Spearco FMIC
2G Ported Manifold
Let me know if anything is needed for it to run smoother, etc. etc.
-Taylor
filter, intake, larger injectors, fuel pump, afpr, fp gauge, safc2, pocketlogger, short shifter, energy suspention bushings, act 2600, ported o2 housing, wideband, partredge in a pear tree..
hey whats up westcost
*ACT 2600lb Clutch*
2" Drag Springs with *KYB AGX Struts*
Konig Rims (What size?)
Big 16G Turbo
Spearco FMIC
2G Ported Manifold
*Evo 02 Housing or Ported 02 housing*
-Taylor
What will you use to tune? Maybe a SS Clutch line and Oil Feed Line? MBC set to what? Anything in Bold with ** is what I think you should add/change good luck with it.
out there said:
after reading a couple of your posts, someone had better be following you around and correcting you
I hope you are joking, if not eat a fat one
i'm simply referring to you not being totally accurate in your responses... only 400hp from a 255lph fuel pump? ok...
kyb agx struts
tubular o2 or 02 eliminator turbo back
mbc
injector 550s prolly for your setup
fuel pump 190 prolly for your setup
intake dejontool.com
k and n filter
apexi afc
those are what you need to add to your list in order for it to work properly or safely
ryan
I like the mods that laser_craver suggested, simple, easy for me to afford, but enough to make it run properly. thanks!
If you read the entire post I said I THINK not IT IS so maybe you should be a tad more considerate.
