- Thread starter
- #51
MNGSX
- 2,533
- 25
- Mar 30, 2003
Bloomington,
Minnesota
That site is under construction but what is up looks nice.
The injectors are really bosch CNG injectors (4.6 DOHC CNG crn vic) but pass alcohol very well and function as far as ECU injector dirvers are concerned just like any other low impedance injector.
They require a bigger inector boss at the rail. So more reason for the custom rail.
I'm still toying with pump ideas.
Idea 1.
I've seen some good prices for used mechanical pumps on bay and some used race parts sites. So a used enderle, hilborn, KSE etc might go on it. I have found some small plastic fuel cells originally designed for drag rails. 3gallon or so. that would fit up front.
Idea 2
Is an electric pump araingement. Maybe even two intank and two inline. I may have some help thru a distributor here. It's a me only deal so no GB.
I've been busy at work too. I will get things figured out.
I'm doing an exhaust redo as well. I have welders an other stuff at work now. I have found a way to make it straighter simpler and better. Were talking an easy VFAQ like way to build killer exhaust.
Idea 1.
Idea 2
