need Haltech fuel and ignition maps for 4g63
nigma
56
Dec 30, 2002
Hello, I've just got my E11 ecu kit and I'll be installing it soon. Fuel and ignition maps from E6k users would be a very big help for initial tuning. It would speed up my fine tuning on dyno. New E11 halwin software can import older ecu fuel and ignition maps so if you have one please send me. It would be of great help!
Also write me what injectors and what fuel preasure you run. You can also write me if you want or have information on how much hp did you make with what setup. :)
I'll share my information after installation and tuning of this new unit :)
Tevenor-
If you check the poster's location, you might consider that english is probably his 3rd language.
I thought he did better than most of the American posters of late.
you must understand that english is not my native language and not even anything close to it, and that i do not realy have that much time to double check every word i write. i type more then 200 chars per minute i'm very skilled programmer, i could even design my own ecu, but i do not have time for that too, you should have some kind of exception for ppl like me :) that would be nice. anyway i'll try type slower and check what i write next time. rools are rools
respect
respect
:thumb:
You still posted better English and Grammar than a good portion of the 'members'. :D
you can find some maps for 450 injectors on yahoo groups haltechdsm.they got me up and running just go easy untill you tune it for your setup.i have many maps for up to 1020 injectors let me no your setup,boost,gas,and how much hp you are looking for.just start with a small amount of timming(15)and you should be fine.
I have injection clinick 650cc disk style injectors,
the pump gas is 98
maximum boost is unknown yet but not more then 28 psi :)
HP: as much as possible i dont know yet too
ok... so i still need fuel and ignition maps.. E11 ecu is in place working fine (after not so easy instalation) but it happen so that oxygen sensor on dyno broke :(( so i can still benefit from any working fuel and specialy ignition maps from E6k or E11 ecu
  • For sale 4G63 Parts
    Transmission starter plate fits 2G DSM 7bolt engine for Auto AWD or FWD and FWD Manual...
    • Dsm_canadian_mike
  • For sale 1g coil pack
    Used 1g (91-94) coil pack and bracket. One stud to mount the harness is broken, but still has...
  • For sale 4G63 OEM Balance Shaft Delete Kit
    OEM Balance Shaft Delete Kit $40 + shipping and PayPal fees* includes crank spacerYou must...
  • For sale Evo viii fuel pump
    Used Denso Evo 8 fuel pump. Similar flow to the Walbro 190. Plug n play for 2G's. Been...
  • For sale 2g 2G Hatch Weather Seal ( no rips or tears )
    2G Hatch Weather Seal $45 + shipping and PayPal fees* no rips or tearsYou must be...
