hose101772
- 290
- 0
- Aug 15, 2002
murfreesboro,
Tennessee
If you're going to depend on vaporization for intake charge cooling then you need to move the injectors as far away from the valves as possible.Think outer end of runners.Also I dont think you need to worry with top end oiling,to make big power your rings are going to have to be loose.The factory e85 cars only have injection changes to run it.You should be fine there.If was available here i would run it but its not,so i dont.Anyway you seem excited about it so shut the hell up about it and build it already.(joke-sorta)good luck.
That poor poor automatic transmission. It's getting used and abused.
