1G Setting Timing
1SIC1Gb
353
73
Jun 25, 2012
Houston, Texas
Ok So my spare motor just got a rebuild and i am installing the new timing belt, As i understand it, i need to set the timing to 5 btdc off the Timing cover?
Also the new engine has a 90 CAS, and my car has a 94 CAS, So i am going to have to swap over the 94, am i wanting to set up the timing light and get it where the timing stays at 5 BTDC?
Adjust your CAS so the timing mark on the crank pulley lines up with 5* mark on the timing tab on the timing belt cover when u put the light on it.
You're confusing ignition timing and mechanical timing. The belt has nothing to do with the marks on the cover. The timing belt controls mechanical timing of the valves. Procedures for installation have been beaten to death on this forum. CAS controls ignition timing which is when a spark happens relative to crank position.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
