Separate dimmer switch for my gauges ?'s
turbotsi90
96
Mar 4, 2008
Salem, Oregon
Hi guys, is it possible for my to run a separate dimmer switch for my aftermarket Faze gauges? I have the boost gauge now but will be getting a oil & AFR gauge.
I have the boost gauge hooked up to my dash light dimmer but would like to run it to is own.
If this possible?
Thanks again
thanks for the link
Here is a link to the gauge I have if it helps any, Faze®
The dimmer suggested above is a PWM dimmer for LEDs. It is not likley to work well, if at all, with electro-luminated gauges.
If your EL power supply/tranformer does not come with a dimmer control option then you'll have to try to find one that allows for dimming from some other vendor.
