flipgsxtacy
- 0
- Apr 2, 2012
south el monte,
California
I am selling my 1998 Silver Mitsubishi Eclipse GSX. It is highly modified. New Tires. New Spark plugs. New Battery. Clean Title NO SALVAGE. Smogged and ready to go. Pink Slip in hand. Motor was built by Roadrace Engineering.
Here is a list of the Mods.
Stock 7 Bolt motor (4g63) has been removed and swapped out with the built, stronger 6 bolt 4g63 motor. Motor internals... Stage 2 port and polished head, HKS Cams, Wiseco pistons, eagle rods, ARP head stud kit. Polished crankshaft. Balance shaft removal kit. Extrude and Honed Stock intake manifold. Denso 550 cc Fuel Injectors. Big 16g ported and clippped turbo. ACT Extreme duty clutch, Roadrace engineering Lightened flywheel. Quaife center differential. B&M short throw shifter.
Engine Management
Fully Tune your eclipse with a modified ECU through yourlaptop. ECU has been modified by ECM Tuning. Recently upgraded to support USB. Cable and program included. Greddy profec B spec 2 boost controller, and Apex Super AFC.
Exhaust
Greddy Power extreme exhaust, Rsr Downpipe, Tial 35mm external wastegate with dump tube.
BBK upgraded fuel pump,
Greddy front mount intercooler, Greddy Type S blow off valve. Fluidyne radiator, Injen intake, Magnacore Plug Wires. Roadrace Engineering catch can
Triple guage pillar mount With 60mm Greddy boost guage, 60mm Greddy exhaust temperature guage and pro comp air fuel guage.
Eibach Pro Kit Springs, Front And Rear Strut tower bars.
Stock Radio and power antenna still work. Interior is stock. Headlights have been upgraded with HALO eyes. Power sunroof and windows work.
I also have extra parts I'll throw in that you can keep or sell.
Stock headlight housing. Stock muffler, Stock Springs, a manual boost controller and an additional electronic boost controller mounted in the car. (Greddy Profec A) I'll even throw in a front Veil side bumper that is in repairable condition.
The Bad
Driver doorhandle outside broke off. Small dent on driver rear quaterpanel
No low ballers or trades please.
Text me for a quicker response (626) 478-8707.
Pics
Engine Management
Exhaust
The Bad
Engine Management
Exhaust
The Bad
Pics
