scat rod qorque spec with apr
CBRRACING
Jan 18, 2009
middletown, New York
i just need the torque specs on the arp bolts i found eagle rod torque spec but i dont think they would be the same
Scat, Eagle, Manley, all the same using the same ARP bolt. 40ft lbs with ARP moly lube. Torque, loosen, torque, loosen, torque. Unless you can measure rod bolt stretch which is preferred.
In that case it's .0058"-.0062" of stretch.
After you build enough motors you don't even need a sheet LOL. You just remember.
my rods didnt come with the sheet and i got them brand new just the arp lube thanks thow
