SBR Man. Boost Controller:
Joey4g63
Jan 8, 2007
Glen Burnie, Maryland
Hello, i know this has been gone over hundreds of times probably, but could'nt seem to find a link to SBR's controller install? if anyone could help me id greatly appretiate it. Thanks guys in advance.
I guess my real question is which side of the controller goes to the Wastegate actuator, and which side goes to the J-pipe? Horrizontal/vertical?
I've read not to attach to BOV?...thought it was the J-pipe, because of shorter route
Yes you are right, do not tee it off at the bov, run it from the compressor housing nipple, or from the spot on the j-pipe depending on application.
Well I am sure alot is preference on how you want to run it and where you get a better reading from.
That image is straight off slowboyracing and the instructions on how to install that specific controller.
Michelle
Michelle
DO NOT T into the BOV line. You do not want to steal from the BOV line. It can lead to inaccurate boost control, bov flutter/compressor surge, among other things. The BOV and MBC need dedicated lines. Either tap your j-pipe, or another intercooler pipe.
Correct, the proper place to source the MBC line if from the compressor housing or "j" pipe. And correct that both the BOV and MBC should have dedicated lines for their operation with NO taps in the line.
