SBR fmic question?
mitsuclipsegsx
2,561
8
Apr 5, 2004
Dover plains, New York
Well me and my buddy installed the sbr fmic short route, boy it was a pita, got some questions.Is my bov suppose to be that off from the intake, i donr want to vent. and the lower pipe is pretty close to the 02 dump, is that dangerous in any way, i have a different setup going on in few weeks and i wont have the 02 dump anymore.
thanks
Is it possible to rotate the bov 180 degrees? Would that be closer to lining up?
Rotating the BOV 180* would only turn it towards the battery. It looks like they welded the flange on crooked.
An easy fix would be to get another 2g return tube, attach it to the BOV and get a piece of PVC or metal pipe to join the two. If you do that it looks like they should line up with each other if you positoin the bends the right way. Just make sure to silicone the hell out of the joining pieces to eliminate one more possible boost leak.
As for the dump on the licp, that pipe is going to get really hot if you are constantly boosting but i wouldn't worry too much if it is changing soon. Just lay off the boost for a little while
