SBR Cast Manifold
vr6chris
149
4
Jan 1, 2004
Silver Spring, Maryland
Hey, I know the sbr cast manifold has been discussed about. But I have not seen anyone with the new one on their car. If anyone could provide pictures and how you either like or dislike it. I bought one, but its out at jet-hot right now. I should recieve it today, and it will be on later and i'll provide pictures, if I do recieve it today. Just wondering if anyone else has already put good use to it. :thumb:
I have one on my 92 TSI. Been on over a year now, no problems with it yet. I had to gasket match it to the head, took about 2 hours with die grinder. Had to grind it in a few spots, it has a thick flange on it. Slowboy ported the turbo side to 7cm, and supplied the turbo SS gasket. I have a Evo 3 on the car and performance is great. Yu will like it.
CanadianTSi said:
It just came out a few weeks ago so I'm not sure how you've had one for a year...
true, the new model has only been out for a while however ive had mine (uninstalled) for almost a month
He obviously has the earlier model (without external waste gate option)
Got the manifold back from jet-hot today. Looks real good. I also have pictures of it on the car as well, but they are pending in the gallery. Ill get them up soon. Overall install of it, wasnt bad. I had to grind a little off on the timing belt side of the manifold to get it in there. Its a lot thicker flanged manifold than a 2g, which is what i was using before. Overall, im happy with it, but I havent taken it out for a ride yet. But im sure ill see some nice gains with it
Heres some pictures of it, finally installed.
130 all said a done. it is the 2000 coat. which is good up to 2400 degrees.
i have the new one, ported and all. Very good looking piece if I may say so myself. Here is a pic of it test mounted, I'll have pics of it fully installed and the rest of the car together soon.
IS this the place for the EGT probe
Slow boy racing cast iron race manifold
It finally arrived a couple of weeks ago. i ordered it fully ported. the port work is amazing on it. it mates up perfect to my bullseye housing. i really can't speak for the hp gain. all i can say is that my spooling has never come on faster, and the revs have never felt sooo smooth. this thing is just a work of art. but you don't have to take my word for it. See for yourself.
i'm very pleased
SBstar said:
Man SleeperG, I ordered mine fully ported, but yours looks to be ported a lot more then mine. Did you ask specifically for them to port it very liberally?
nah its matched to the head, then the runners stay the same diameter all the way to the collector.
such a perfect port job, its like it was cnc machined that way. i'm very satisfied with it.
the other manifold in the pic is an unmodified 1g manifold for comparison.
Just stopped in for look. You are correct I have the early verson. Was not aware of the new and inproved verson. It looks like another SBR winner.
Anyone use it with an external? That will be my sole reason for getting one and I'm a little worried about clearance with the stock AC fan.
The new SBR manifolds are great, and you definately can't beat the price. It will out live any tubular manifold and works better than any ported 2g or Evo III manifold.
Werd, his mani looks mutch better than mine....
My runners are identical to stock and are not as clean.
Wow their new mani looks great. I have one of their mani's from before the redesign and was very happy with it and still am. With the new one it looks like they've changed how the runners feed into the collector area quite abit as the origional design was basically like the mitsu design. I wonder if anyone has any comparisons between the origional and the new one as far as hp/torque or spool time?
