SBR 50 trim vs Evo3 16g
98turbo
296
11
Aug 22, 2004
Mobile, Alabama
This is the graph in comparison to my last Evo3 16g pull. The 16g is on 25ish psi...
And this is the graph on it's own. SBR 50trim with stock head on 20psi....
SBR stage 2 block, stock head, RRE O2 eliminator DP, FP 4" intake, DSMchips 3 chip, Safc 2...
Good stuff! Other than the initial "hit" of the 16g (from about 3200-3800 which is typical), the 50-trim pwns the 16g every where in the powerband! At 5psi less boost too. And I'll bet the launch and control is more predictable with the 50-trim. And at the strip you're never that below 4500rpms anyway.Same power from 3800-4600rpms, then the 50trim just pulls away. . . So much for a tiny turbo to have a fat powerband :)
