same design?
DSM "BISH"
241
Sep 10, 2008
Erlanger, Kentucky
I was wondering if the turbo 2.0 liter 4g63 is the same as the naturally aspiated 2.0 liter 4g63's and if not what are the differences besdies on is turbo and the other is notROFL?
thanks
yes ... same thing outside except the N/A 4g63 has weaker internals but higher compression, no turbo (obviously) ... makes the same 140-ish horsepower as the 420A motor ...
N/A 4g63 motor is only in canada, europe, japan ....
oh right they are in the 1Gs i forget... they had the 1.8 and 2.0 's ....
Actually guys the N/A 4G63 2.0L was in all N/A cars built from 90-94 it was the engine they used in the models of cars that were not the base models which got the 1.8L motors, but also were not the high end cars with turbos. The N/A 4G63 2.0L heads cams are different then the turbos and it is also missing a few of the sensors like the knock sensor that the turbo motors have, but the internals are the same as the turbo motors just with a higher compression.
I believe the 93+ can be found with 1.8L's, but the 1ga's are pure 4g63 2L engines. (fact?)
The NT pistons are more than different in the CR, ringlands and such are very weak vs the turbo pistons.
