safc2 ???
sweet thankx a ton... i almost bought a knock box when im going to be getting a safc2 soon to LOL...
ryan
np don't forget to read the manual and if you can't tune it take it to someone that can bc it can hardcore screw up your engine :thumbdown but then agian it can make you run enough fuel so you can get the times you want. don't forget supporting mods =) :thumb:
the safc 2 does display knock, but it doesnt do so correctly on our cars. it is still a VERY worth while mod, but do not be tricked into thinking it will read a correct knock count. i have seen them read upwards of 60 counts when the max is 42. invest in an safc and a logger and call it a day.
so you your saying just get a plan safc??? i was panning on running and safc2 and a maf translator... get the over setup done with the maf and then fine tune with the safc2
can you give me a good link a pocketlogger i couldnt find any that i liked...
ryan
now do i just get that cable there and plug it into a labtop or sumthing after installing some software??? what all can i adjust with that???>
ryan
sorry, i still meant the safc2. you just dont want to go by its knock count. the link above is where i got my logger from and its worth every penny.
i read that it measurse knock and everything the only thing i dont like about that one is it doesnt have the dyno feature but owell.... and what else do i need to run the logger suggested?? what all comes with it for the 175 bux??
ryan
ok nm i read further and all i need is a pda and a cable to attach the pda.... what is the bet pda to get do you all think??? and do i need an eprom to run this to??? i was gonna get a dsmlink bu i aint got a eprom :thumbdown so know i will keep the maft and safc2 and then get this pocket logger... i can get almost any pda for free since my dad gets em for free at work i just need to know which one i should get a model number would be helpfull
ryan
ryan
You need a car and a Palm. You would know this if you checked their site instead of starting similar threads in multiple forums.
Searching is also the cat's PJs.
sony clie s360's are cheap and much, much more attractive and easier to read than the palm m whatever people usually recommend. check ebay.
