Safc2 Problem
MAKASHIFWD1
Jan 4, 2005
NATIONAL CITY, California
done the search didn't realy find info lookin for..just installed safc2 and now it idles rough, got the right instructions for the install everything works except it idles rough like its going to die. only feed back i got was that it might be my ground being too far apart..but besides that ### else could it be..thanks:(
go to car select- make sure you are 4cyl.- and angled up, then go to sensor select and make sure that you are on KARMAN, then go through and make sure everything is zeroed out- if it is still rough, check your BISS, and boost leaks
sorry, what is BISS? and i'll go ahead n check on those other things u mentioned..thanks
