safc2 problem/ or maybe not?
StreetTunedTSi
56
Apr 23, 2009
East Petersburg, Pennsylvania
OK, so the problem im having might not exactly have to do with the safc2 but, i tuned the car my self i read up on it a decent amount, car ran fine for a while, but now i cant got wot without the car breakin up alot, the a/f ratios are between 10.5-12 @ smei to full wot, but car runs fine under cruising a/f stays between 14.6 - 15.3
my low settings
1k,0 2k,0 3k,-7 4k,-6 5k,-6 6k,-5 7k, -4
high settings
1k,0 2k,0 3k,-22 4k,-20 5k,-18 6k,-16 7k,-14
low throttle is @ 25% hight throttle is @ 75%
karmen sensor type, 4cyl with arrow up selected
you can look at my part set up, im still on the t25 set up not 16g.
Thanks guys!!!
ok so i treied -5 all accross the board, and my a/f was deff reading 10.0-10.5 rich as shit LOL hmm maybe not a safc. boost leaks? clutch not holdin what its suppose to?
+1. I found 11.4 is the best for my car. But everycar is not the same. 12.0 does seem a little lean...try to richen it a little more and see if it helps
yea deff 11.1-11.4 is ideal mine stays within the good range but it will richen up and sputter under racing conditions if you know what i mean, but at least its not a lean miss.
