safc setting yes ive seacrhed
lmarinukjr
Sep 6, 2006
philadelphia, Pennsylvania
Ok guys, i just bought a 92 eclipse and i found gold tucked next to the ecu. Its a safc almost completly installed. i finished installing it now i realized i dont know how to set it. My mods are few my car is tight no boost or vaccum leaks. k&n filter 2 1/2 cat back. Initial setting is done now how do i finish setting it.
Ok ive set my THpoints at 30% and 80%. I had a problem setting my ne pionts I got it to 1k 2k 3k 4.4k 5k 6k 6.4k 6.6k 6.8k 7k. Is that ok?
i also had a slight problem finding the section to set my baseline for my injectors.
Ive read them I dont have the manual this is the first time ive seen an safc in a dsm.
I could tell you exactly what you want to know, but if you don't understand what you're doing you could damage your engine. I suggest you keep reading the guides, as well as these:
http://roadraceengineering.com/newafc.htm
http://roadraceengineering.com/newafcsetting.htm
If you read those a couple times and you're still having trouble, PM me and I'll walk you through it step by step. I also suggest you get a datalogger, because without some sort of feedback you aren't going to know what to adjust.
