safc compatible injectors
micus
53
Dec 17, 2005
p-ville,
hey guys, im seeing some REALLY good deals on srt4 570cc injectors, APaRENTLY they work on dsm's , so i was wondering, DO THEY????. also i know its very hard to tune injectors over the size of 650cc's with safc, but can i use any size inbetween, like for example 550's, 560's 570's or 580's? or will safc only work with set injector sizes, im still quite fuzzy on tuning with safc.
thanks in advance....:talon:
Anything under 660's should be fine on a SAFC. If you can use the SRT4 injectors then you shouldn't have a problem with them on the SAFC. It just "tells" the ecu a different amount of air to compensate for the injectors.
