1G ECU/injectors/turbo compatible? :/
classic69
48
Mar 30, 2005
Binghamton, New York
i have an automatic 92 turbo awd talon and i put a 14G turbo on it from a MT turbo laser and im using an ecu from an NT manual car. is this a problem, should i get injectors from a manual car too ? (450cc) , also should i get a turbo awd ecu because this one works great except for a really crappy idle :/
an NT ecu will even work on a Turbo car, I didn't think it would?
Interesting. I'm pretty sure the NT ECU doesn't have a knock sensor hookup. I guess if it works I'd be carefull. I would get a turbo ECU if you plan on doing anything but driving very carefully.
It will start but run crappy and they don't usually have a knock sensor.
Your better off with the auto ECU than the NT ECU. If you put the 450cc injectors in then you would need the Turbo MT ECU.
Why are you running a NT ECU?
Steve
I maybe wrong here but isnt the timing going to be way too advanced if he uses a NT ECU. This could be very dangerous and you also don't have the knock sensor output to watch that. I would not suggest using a NT ECU.
