S362 Track Results
me612
1,423
5
Aug 8, 2002
Minneapolis, Minnesota
Ran a new personal best. This was around 32psi on a T3 .70 S362. Car weighs 3040 w/out driver. Still has full interior, air conditioning, etc. Not much weight reduction done to the car. Car was knocking bad as I believe one of the fuel pumps died on me. So still has a lot left in it once I can get the AFR's right with a new pump setup, and some better 60' times.
Here is the slip, I'm on the right.
I didn't get a video, but a couple other people did. I'll post the video soon as I can.
YouTube - Halon going 10.93 @ 137mph
You can view the dyno sheet by following the link. It was SAE corrected power, which displays a lower number than if it were to use the STD corrected number. I typically use a Dyno Dynamics though, which last time I was on it I made 541 there. Around a 16% difference between the dynos.
There are pictures of my setup all over. Do a little searching and you should be able to find lots of pics.
Good run!
What kinda wheel/tire set-up are you on?
My car weighs a little less than yours 3030 w/ me in it and i'm 175.
A better 60ft and 330 and you be running mid 10's woohoo!
Looks like the s362 is performing very similar to the 35r's and 6262's out there.
