90 TSI FWD
- 281
- 45
- Oct 26, 2004
Vacaville,
California
Hey guys, I recently took out my small 16g because my car blew blue smoke when I boosted. I took it apart to change the seals/bearings and send the parts (shaft, wheel, nut, in/out thrust collars) to FP for balancing, yet I noticed that the bearings had worn into the shaft itself. The wear isn't deep at all, but noticable when you slide your finger across the shaft. Can I reuse this shaft? I personally think it should be okay. I'm thinking that when I put everything back together, I'll just have a small amount of side to side play, but other than that, the bearings and seals will be new, which is my main concern
What are your opinions on this?
Thanks
Thanks
