Archer Fabrications
- 9,719
- 706
- May 9, 2011
Scottsdale,
Arizona
Hey guys, I'm trying to purchase a pre bent cage and had just a few questions.
Is the chromoly cage NHRA approved/will it get approved? They say it's 1 3/4 .083 wall chromoly
But when i look at the nhra specs i see they are requiring different sizes of tubings? Is the fact that everything is 1 3/4 fine because it's still larger than all the other specified bars?
I just want to be positive I'm getting the correct spec of tubing.
http://www.swracecars.com/store/199...SE-8-Point-Roll-Bar-OSCARItem_31=11-2044.aspx
I'm just getting the 8pt and I'll add to it as needed. But the goal is to get certified for 8.5 ET eventually after i add to it. Until then being good for 9's will suffice.
For those of you that do have this cage, did it fit well? I know they come over sized and it's cut to fit but I'm curious with anyones over all experience with it as well.
Also if anyone has any other suggestions of pre bent cages i can weld in I'm open to it.
