running too rich or too lean?
deviousgst
931
Mar 24, 2008
bakersfield, California
i recently got my motor rebuilt(forged Je pistons, eagle rods and cometic gaskets)(my mods are up to date) and since then its been cutting out wen i hit WOT. My set boost is at 20psi. Wen im like at 3krpms i hit wot and drags(hesitates) up to 10psi and anything after that it starts to cut out.
i havent got it tuned yet since i got it rebuilt can this be the problem. or is it jst running to rich or too lean...
thanks in advance
Your stock fuel pump wont push enough fuel to your injectors once you start running about 16psi. You said you are running 20psi.
As I previously stated your not getting enough fuel with all that extra air your getting from the 20psi. You need a bigger pump, simple as that. If you turn down the boost I bet your car will run just fine. So either get a fuel pump (190lph, at minimum, or a 255, but then you need a afpr) or turn down the boost.
Edit: You cant tune what you dont have. You dont have enough fuel and you cant make the pump push more by tuning.
so how is it that when i first had my car i was able to boost 20psi no problem and i even tried 26psi and it ran great(no hesitation or nothing)..But since the rebuilt its been running like how it is now
How much boost were you running before you rebuilt it.
Either way, you NEED a fuel pump, the stock one is simply not going to push enough fuel.
Pull your pump and see if its the OEM or a aftermarket one.
You should ###### get an SAFC of some sort. Ive heard of people pushing the limits of the stock fuel system... 18 psi with no fuel cut. But yea, 1st thing you should of got was the Walbro Fuel Pump before injectors. 450's can go along way.
I am having the same problem with a 255 welbro pump and 550cc injectors. Doesn't cut out in first gear but at about 4,000 rpms in 2nd 3rd adn 4th gear it cuts out and hesitates..im running 18 psi
Yea, your going to need the following with an upgrade Fuel Pump & Bigger Injectors:
Adjustable Fuel Pressure Regulator
Air/Fuel Controller
AFPR to adjust the psi of fuel
AFC to controller the injectors pulse rate and compensate for fuel usage
I just put in a wideband and have a SAFC and an hour after i got it tuned and was running and spooling great then it started cutting out and hesistating
I have a fuel pump regulator. i might be running a little lean if anything but i have had people look at it and they don't think its a fuel cut ### it only hesistates but i dont think its a misfire
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 1g WTB: 4 Bolt Axle Cups.
    Looking for a set if 4 bolt axle cups for a 1g. Located in Canada.
    • blaster1812
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
