2G Running S90 TB with shaved manifold
Bedicine
542
192
Jan 3, 2022
Toronto, ON, Canada
Hello
Was curious if anyone has run or relocated the throttle cable (non cruise) where it doesn’t bolt to the back of the manifold. I have a shaved EVO3 manifold but wanted to go back to cable But have no where to bolt it to?
Thanks
The throttle mount was shaved off??? You'll have to get creative and make your own mount or weld one back on.
It was a dbw Bosch unit or so it looks like in the picture. You’d have to weld another bracket to it but you have a different flange anyways so I’d probably just sell those as a whole setup and hopefully find another manifold.
I have also seen where you can cut the cable to whatever length you need. Then take a block of wood and drill a big hole (which will be the new metal ball end) and a small hole sideways to feed the cable into the big hole. Then unravel the end that is poking through the drilled hole and cut bunch of solder to stick down in there. Get a blow torch and heat it until it all melts together into a ball. VIOLA, custom short throttle cable.
