Running Larger Cams
TommyDSM
241
8
Aug 2, 2003
Somewhere, New York
On my car I have WebCams, DSM Translator 2.0, AFPR set at 43psi. When I start up my car when its cold, the car idles low and wants to die... If it hold the RPMs up for a minute then it will idle fine. If I turn the switch on the DSM Translator that richens up the idle when the car first start will that fix the problem? Or Should I reinstall the Factory Fuel Pressure Solenoid to fix that problem... Right now I have all my Emissions removed, is there another way around this issue.
