Guys Running FP1X cams, Help
daren_p
DSM Wiseman
4,605
98
Nov 22, 2004
Newmarket, ON, Canada
These cams are driving me crazy, I can't seem to get rid of knock unless I add lots of fuel (basically back to stock air/fuel), or take away a couple degress of timing from 5000 rpms up. Im not trying to run a huge amount of boost (on pump 94), currently at 17 psi, but would like to atleast run 20. If I turn up the boost anymore the knock continues to increase & I'm not even seeing the airflow I was pre cams (as I could run 22 on pump without knock, 11 to 1, 2 deg of timing added from 6500 up). So guys that are running these cams, what kind of boost can you run, what fuel, hows the car tuned, logs would be great if you have them. All my issues can be seen in this other post, thanks:
http://www.dsmtuners.com/forums/showthread.php?t=236618
Here are 2 logs (dsmlink) I took this morning, while the first pull looks pretty good, there is a good amount of knock in the second (the -2 file) & I didn't adjust anything.
