Running Horrible
esfry
Jan 20, 2008
Lancaster, Pennsylvania
91 Talon TSI
Real EvoIII 16g clipped
8.5 to 1 compression
Digital Alcohal Injection Kit
Car was running great and boosting around 25psi with Lambda around .76 on my WB.
I noticed the temp gauge climbing so I pulled over and shut down before hitting the red.
When I got out of the boost I noticed the car was shuttering and running horrible.
After I shut it down I found lower coolant hose leaking, about 50% low on coolant.
I filled it back up and drove it down the street to let it sit overnight in a secure spot.
It did not overheat, and the temp stayed in the middle until I parked it, then it slowly started to climb.
It poured grayish smoke out of the tailpipe when I accelerated, but would stop as soon as I would hit boost.
In boost it runs perfectly normal, not shutter or roughness, and full power.
Again, I thought head gasket.
So, I just performed compression test tonight and I am right around 150 to 155 across the board.
What should I be looking at next (aside from fixing the coolant leak of course)?
I would not think a bad plug/wire or vacuum leak would cause the large amount of smoke that is coming from the tailpipe when I am not in boost?
E
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
