Running 2g without air filter cover?
To further explain @motomattx reply. The top side of the factory air cleaner box is the filtered air side. The bottom is unfiltered. By leaving it off you would have no air filter. Also the intake air would be hotter because it would be sucking from under the hood instead of under the fender.
  • Wanted 6 bolt NT water pipe
    • chrisman287
