RTM rear subrame bushing installation
SasaniFab
2,432
788
Dec 1, 2013
Mexico, Connecticut
I just wanted to be 100% sure when I go about installing these bushing. I burned out the rubber and metal insert "pin", im now left with a metal sleeve that has notches in it inside the subframe. The website says you need to retain this? or Do I need to press this out to install the bushing in?
Not sure what you mean by notches. Here's mine all cleaned up and ready for the new bushing. I dont remember any notches on the sleeve that remained.
when u burned out the bushing......there was a metal sleeve left. You pressed that out correct. I got the impression from the website that the first design by tuner nation required you keep that in? I burned the rubber out and banged out the metal sleeve the bolt goes through. There is an outer sleeve left. Did you press that out?
ok thanks man, i figured thats what i had to do. But you never know with these damn cars. I gotta finish sand blasting, weld in the jays racing toe eliminator and then i can get these bushings in
