RRE Harness connectors?
sakrafice
217
May 28, 2003
Sumpter, Michigan
Okay, so I done all the necessary work to my 95 tsi for the 6bolt, installed motor, trans, 14b.... and well im to the wiring and I got the rre cas harness so me and a friend started wiring the rest of the car up and connecting the rest of the hoses and such... the problem im having is I cannot find the second connector plug that goes to that harness! It was a little dark but I looked for quite some time and could only find the black one which looks like it was the crank sensor... where the heck does the grey connector go! Anyone that has done this swap please let me know were to find it. I thought maybe that sensor that just bolts to the block (behind intake) but the connector on its different, and I can’t find the other one since I had 2 of them to see if one was different from the 1g and 2g block…
And there are a few other connectors near the battery I cant seem to find connectors to being orange/grey/black. I’m running a 2g head as well.
Pictures, Info would be appreciated! thanks :thumb:
I just did a 6 bolt into a 98 with the RRE kit and you have what you need, Hook one end to the cam plug and the other end to the crank plug and the whit wire goes to the middle blue wire in the original cam plug. Then I taped up the end of the old cam plug.
wait a sec, so i gotta swap wires in that harness? i have a 95 head on a 91 block. with a 90-91 green cas.
And I thought the Harness dont need pluged into the crank angle sensor since the CAS does both??
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
