rpms dropping
dustint265
Apr 4, 2009
mansfield, Ohio
so just got new 16g. fmic bov and manifold.. well after get the leaks and everything fixed and boost leaks... now my car after running a little while the rpms will drop wen i take the car out of gear. almost stalling out... what could i do to fix it
First of all, dont make multiple posts for the same subject.
Searching usually works good too - type in "stalling".
Like said. Check your ECU. Refer to this link
ecurepairhome [ECMTuning - wiki]
Ohm test your ISC. - VFAQ Site - Visual Frequently Answered Questions It's in intake.
Verify those first. Then report back. IF you have a lightweight flywheel your always going to have this problem since the reduced weight lowers inertia.
