rpm high on slight accel
dboned
Jan 8, 2010
michigan city, Indiana
i have a 97 eclipse rs non turbo. 420a and i am having a problem, when i press the gas pedal just a slight tap that should normally bring the rpms up to about 1200 rpms then right back down it will raise the rpms on its own to about 3k-3.5k rpms then wait about a second or 2 then come back down, any ideas will be appreciated thanks
we talking manual or auto? Maybe your throttle cable is catching on something, or a sensor aroudn the TB area somehow went bad, became disconected, like your TPS, or IAC
Try blipping it at the throttle body. Take the pedal out of play. By hand, bring it up that slight bit then bring it back. If that works then you are looking for "binding" in your pedal to throttle body set-up. Or see if the throttle body arm is resting on something.
MB
MB
i did it at the throttle body and it still revving super high...i do have a cel i am going to get checked out
I too have this problem. I'm interested as to what you find out. I'm sure it's a sensor of some sort or a vacuum leak.
The problem ended up being the TPS. Changed that and now I am good...thanks for everyones help
Problem ended up just being the TPS...Changed that and now its working proper...THanks for everyones help..
