Accel Injectors
tec_41
342
7
Nov 23, 2008
West Bend, Wisconsin
So I'm looking at a new set of injectors...not sure if mine are an issue or not but they're stock running 7-8psi. The car runs lean throughout most of the RPM range, and I'd just like to upgrade them so I can run 8psi without maxing mine out.
Accel Fuel Injector Set Eclipse/Talon 420a - CI Motorsports
My question is what would be an appropriate size for my application? I'm going to try to use the SAFC to tune them in, yes I know most say this is not the best way...but I'd still like to try ;). I know 190cc is the stock size, so to run 8psi (maybe 10 max with stock internals) with a SAFC II, 12:1 FMU, and Walbro 255 what would be my best bet? Also, would I need a resistor pack with these? Thanks for any replies.
I've heard 330cc is good, have to do some slight tuning for idle but that's about all I know
Thanks for the reply :)
I found a guy on craigslist selling some 250cc's for $100. I figure this might be a good start...
Are they high or low independence? That will determine if you will need a resistor box or not. iirc 420a's are high independence.
Part number is 150124, which are the ones I linked to...Looks like they're high impedance.
accel 30# or 310cc (whichever they are) are good to use without having crazy tuning issues. Especially if you're only using an safc to tune.
PM'd
Well I picked up a set of Accel 250cc's for pretty cheap...I'll give them a shot.
As far as I can tell though I don't think I'll need a resistor pack? They're already high impedance.
hey i think these injectors are the same ones you are looking at for a good price. you get 8 of them in this aution i would split it with you so we each get 4. let me know man.
Accel 150830 Fuel Injectors (8) High Impedance, 30lb/hr: eBay Motors (item 260683536786 end time Nov-02-10 19:00:00 PDT)
if the link doesnt open pm me and i will get it to ya
