GSXRunner
- 160
- 38
- Feb 24, 2013
Queens,
New York
Hello,
I'm replacing my valve stem seals. I hear about the "rope trick" many are using to support the valves when removing the springs. Seemed to be a good idea, so I tried it. Worked well for the exhaust valves, but would not work for intake. I felt I didn't have enough fed into the cylinder for the intakes and had a lot of trouble feeding more rope in. I was twisting the rope as I fed it in (it was the only way to get it in) and even after I got as much in as I possibly can, I still couldn't get the intake valve supported. I decided to just take the rope out and use compressed air like it used to be done; but to my horror, the rope is stuck and I cannot get it out. I tried compressing the valve to make use it wasn't caught on a valve, but it did not free it; seems to be in a knot, probably from twisting it. Any ideas short of removing the head?
