roll up window broken
igopoopy
2,051
7
May 5, 2004
tucson, Arizona
i have a 91 eclipse and the driver side window does not want to stay on track i did a search and every one with the same problem had power windows. is their a cheap fix
Roll up windows have the same problem. If you spray a little silicone lubricant in the tracks it helps a bit. I was all happy when I fixed the roll up window on my girls talon but when I put the door panel back on it worked like crap again so try the lube
