Devilsfutbol17
- 407
- 48
- Jul 27, 2007
Bellingham,
Washington
I started my engine assembly this weekend and everything was going well until I went to install the pistons and rods in the block. I haven't gotten to cylinders 1 and 2 yet, but the rods in cylinder 3 and 4 are touching the block at the bottom of the bore next to the oil passage. I've seen people talking about grinding the block on 63 strokers, but from what I can tell most people are hitting the block on the side without the oil passage.
Is it safe for me to try and grind the block? How much meat do I have there before I hit the oil passage?
6-bolt 4g64 bored to 87mm
stock 100mm 4g64 Crank
156mm rods
87mm 4g64/63 Pistons (1.13 Compression Height)
156mm rods
