force_feed
- 323
- 5
- Jan 31, 2008
Katy,
Texas
Hey everyone!
I have been seeing alot of newer members complaining of ROD KNOCK, and/or asking if a balance shaft can cause a knocking sound.
The answer is YES, the rear balance shaft bearing can go and will sound EXACTLY like a rod knocking.
A few days ago a 91 eclipse GSX came to me for a engine rebuild. The guy told me that he was messing around in town and heard his car to knock, and immediately shut it off and had it towed to my house.
What he thought was a ROD KNOCK, actually turned out to be the balance shaft! But thats not the best part, he actually drove the car for a while with the balance shaft hitting the block....I'll let the pictures do the explaining!
This is the balance shaft, can you see where it been beat to shit!?
Here is the block! Sorry the pic is a little blurry!
So here is my advice to all the Newbies, if you hear a knocking noise...SHUT THE CAR OFF!! If you have some mechanical knowledge, pull the pan and check it out!
DO NOT KEEP DRIVIG THE CAR!
