2G Balance shaft knock?
Cynxe
263
6
Feb 19, 2015
Ottumwa, Iowa
Just slapped a new head on my 7bolt. Bought the car without the head on. Started it right up and it purrs like a kitten. No misfire at all. But theres this knock. Thats not consistent. It sounds like its coming from up top but the head is swapped with new lifters. If i rev it the knock shifts over the whole engine. But its never consistent. And its on cold start. Balance shaft??
The timing belt yes and you will bend valves. The balance shaft belt can be off and will make things vibrate like crazy And the oil pump will be out of phase but the car will run.
Could be balance shafts... bearing failure.
I have also set my balance shaft and oil pump wrong during timing.... car ran like crap.... sooooo much vibration during acceleration, but no knock.
