Rod Knock- Rebuild or buy new engine?
fourgsixthree33
1,244
46
Oct 25, 2010
Athens, Pennsylvania
I recently got rod knock not too long ago. Thought at first I bent valves from the timing jumping but it turned out that the bottom end needs work. So, here I am with a new rebuilt/reman head with a 3 angle valve job, new parts, the whole deal. Bought the head before knowing I had problems in the bottom end. Should have dropped the pan from the beginning.
So, I am planning on getting a short block locally for $150. Needs new bearings due to the previous owner taking out the rod caps. It's a complete short block from a 97 DSM. I am stuck with my 7 bolt head so I need a 7 bolt block. If I didn't have this head, I would find a 6 bolt long block. But that's not logical since I already purchased this head.
The other thing I could do is pull this engine and rebuild it. But with down time, money in the long run, etc. I think it would be better just to get a short block. Then over the course of the next year, build this one up.
What would you guys do?
Man, spun bearing 5th day of ownership. Swapped blocks, now it has no power with the MAF plugged in, and I've done everything. I just leave it unhooked, and she pulls good enough for me to live with.
A couple weeks ago, I bought Evo 8 rods and pistons for $100 shipped to my front door. So, I have decided to rebuild. Bearings are cheap. $32 for the main bearings and $20 for the rod bearings on Extreme PSI.
The rings on the pistons I got look great. They only have 58K on them when the engine was pulled. So I am going to skip out on getting new rings. The seller (very nice guy and trustworthy) said he would use the current rings as well.
I am going to get my crank looked at and see what they say. I doubt there is anything wrong with it but I will explore my options.
So if I already spent $100 on these evo 8 pistons and rods and spend roughly $65 tops for these bearings and for shipping costs, get the crank looked at, I don't think I will be spending anything over $500. Depending on the crank situation, I may not even see over $300. I am honing the cylinder walls myself.
Granite I already bought a brand new head, all gaskets, all timing belt components, and a crap load of other stuff. So that helps out a bit.
Here are some pics of the Evo 8 pistons and rods. I also have a project log here- Eat Sleep DSM - 1G: Frequent Flyer- 93 Eagle Talon TSi AWD
Since it's $35 for rings, might as well
Can anyone tell me which way the Evo 8 pistons face? Dots towards the timing belt or towards the tranny? There was a guy on here who put them in with the dots facing the timing belt side. But wouldn't that be wrong due to the valve reliefs?
Though the Evo 8 has the timing belt on the passenger side of the car, the exhaust valves are still on the radiator side of the engine while the intake is on the firewall side. So you would put them in just like the DSM pistons. So if I put them in with the dots facing the timing belt, it would make the exhaust valve reliefs go to were the intake is.
Right?
The alignment dot still goes towards the timing belt. The valve reliefs will be on the opposite side, but it isn't a huge deal if you don't have bigger valves or big cams. You want to keep the pin offset correct to the rotation of the crank. By the way, the 1g and 2g piston rings will not fit an evo piston. Yes the bore is the same diameter but the ring slot in the piston is a different diameter and requires a different size ring. Evo rings are 1.2 x 1.2 x 2.0mm, 7 bolt rings are 1.2 x 1.5 x 2.8mm, and 6 bolt rings are 1.2 x 1.5 x 3.0mm . Also there are plenty good engine parts on ebay. Mizzumo is one of the good ones. They carry complete re-ring kits which includes nps rings, which happen to be one of the highest quality rings you can get, acl accuglide bearings, and a full quality gasket set. All for around 120 dollars. They also sell packages with the npr pistons, npr rings, and acl bearings for 130 dollars.
I'm loving all these write-ups. If any haven't seen, i have a 99 RS 420a with rod knock due to wrist pin failure, so im babying it for now, but as soon as i have a daily beater im going to tear the motor down and rebuild. Glad to see all the write-ups and work ya'll are doing to your dsm's.
If you truly have a rod bearing clearance issue or a spun bearing than it won't last long.
How are you certain that it's a wrist pin issue? Have you dropped the pan and checked the rod bearings?
Often if rod knock is caught in a very early stage you can install a new set of bearings before it ruins the crank. Once the crank is scored, so is your wallet.
I had a friend of mine who works at a dealership service center check it out. They said wrist pin, however, im not sure if they dropped the pan, he didn't charge me for anything. With that said, i'm dropping the pan next weekend. The knock hasn't gotten worse or louder but im not taking any chances. I'm looking around for a 500-1500 car to use as my daily beater until i can get the motor torn down and rebuilt.
Well let me ask this of the guys who've been working on these ladies longer than i have. Without dropping the pan, how accurate could they really be on wrist pin? I don't believe the pan was dropped, so i believe the mechanic my friend had check it just listened to it with a stetho.
Fu*king amazing info! This has been confusing. Some saying to flip the pistons, others saying not to. I have always thought the piston offset to the crank was the more important concern. Since the evo 8 pistons sit lower in our blocks, the valve reliefs shouldn't be an issue. So I will install them with the alignment dot facing towards the timing belt side.
I did know the piston rings between the two pistons are different. Just as you stated. I did get some rings for the evo 8 piston.
Again, thanks for the info as it will really help me out. My short block should be here Monday or Tuesday. In which I am then going to strip it, clean it, install my evo 8's and rod bearings, then start bolting stuff back up.
  • For sale 2g 2G Clear Tail Light Set
    2G Clear Tail Light Set $550 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
