420A Rod H Arms
Inkdlyfe
438
8
Feb 23, 2016
Summer feild, Florida
Ok so to make this quick and simple spin a bearing and scored my eagle rod bad can I replace the eagle with a oem rod and keep the other 3 eagle or that can't happen I am boosted on 21 lbs and fully built
Ha! A stock rod will not keep up with that much boost. The rods are the weak point of a stock 420a.
Take the rod to a machine shop and see what they can do for you. Oversized bearings can be fitted to make up for material removal.
You could also try contacting eagle and see if they can send you just one rod so you don't have to buy a set of 4.
    • george bromwell
    • pma1123
    • Sdcryan1
