road trip question
mykfwdtalon
73
Mar 23, 2004
omaha, Nebraska
so i am planning to go on a road trip by mid-end of june. from elkhorn neb to yucca valley ca! its about a 1500 miles, my question is if i dont plan on driving it real hard most of the way, should i turn down the boost a few pounds?
thanx ina
-myk_
Boost isn't gonna build if your not on the gas, so if your just cruising I don't think it'll make a difference.
but 65-75 mph in my car(as well as all i would think) is around 3-3200 depending on accel. and thats in boost isnt it?
wow, we both basically posted the same question at the exact same time, im actually going from atlanta georgia to irvine, ca though, good luck.
how many miles do you have on ur talon?
111k on stock block but rebuilt less than a 100 miles, runs good...for now...lets hope for the best!
does anyone know the answer to my original boost question?
Even tho 3k rpms is boosting WHEN YOUR ON THE GAS if you got cruise control set and just "riding along" then no, your not in boost. Boost isn't just an rpm thin gbro. Definately gotta be on the gas for it. Otherwise when I'm at 70mph in my talon (2g) and at about 3100-3500 rpm's my gauge reads about 0-7 vac unless I hit the gas.
You can cruise at 85 while developing no boost.
um, so I've heard. OMG
If you're going to be gettting on it, such as over the Sierra (aren't you pretty much flat 'till there?), you might want to keep it down a bit. One hint: if it's a long hill, instead of running higher boost and lower rpm, downshift to 4th and run higher revs and lower boost.
But if the car's healthy, it should do just fine. My '94 does, over and over.... a 130K.
Not once the car's up to speed. "Boost" is more air than the engine can take in. Once you're cruising, you're usually drawing just a bit of vacuum- the turbo's in a kind of "coasting" state, pretty much keeping manifold pressure close to zero.
ok thanx. tht answers up my questions.
yes defient it is a flat cruise until, for the most part, the Sierra.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
