1G right wheel sits farther out than left??
jonnyox
Feb 3, 2023
Aberdeen, North Carolina
so my rear right wheel sticks out a good amount farther than my left after i lowered my car. is there any way to make them even without cutting my track bar? if not, has anyone ever cut their track bar?
did you resolve this ? my 1992 laser fwd is sitting the same way only WORSE. The driver side rear wheel is poking out like it has a huge wheel spacer , passenger side is severly sucked in . Just now getting around to understanding these beam axle suspensions. from what i know the track bar is not adjustable correct?
looks like the drivers is more cambered and that's the visual I'm getting from it. have you confirmed camber is perfect both sides
i’ve spent hours searching for forums on the track and trying to find adjustable track bars but found nothing. i think i’m gonna try to cut it shorter and get polyurethane bushings to see if it’ll fix the issue
i have -4° on both sides on the front. last time i was aligning it was 0° on the rear
have it re-checked. the top looks more angled in so that's why i start with a visual check.
  • Wanted 6 bolt NT water pipe
    • chrisman287
