awd front left axle in fwd?
It's basically that easy w/ 1990-1992 fwd cars. But I know 2g fwd shafts are a larger diameter(also stronger) and I believe the 1993-4 1g cars have a larger diameter half shaft. This larger diameter changes the spline count and also the differential neccessary to drive the axles. A good set of UNCUT (no regrinds) AWD axles should be used and both sides will be required because the AWD front differential is needed.
http://www.dsmtalk.com/forums/showthread.php?t=129863&highlight=halfshaft+fwd
http://www.dsmtalk.com/forums/showthread.php?t=9255&highlight=halfshaft+fwd
