Right headlight blinker stays solid when headlights are on
ayyyalexxx
37
Jul 4, 2013
Rialto, California
So I've noticed that my right blinker (on the headlight) stays solid when my lights are on. It works fine when the lights are off and when my parking lights are on, just not when my headlights are on. I've checked grounds, fuses, etc. and they all are fine. My right foglight is also out (or I forgot to plug it in when I put the bumper on, oops) so I was wondering if it might be the foglight that is causing the issue? Anyone ever experience something like this on a 2G
i have had a similar issue. i used contact jelly on all the fitting removed my foglights and then replaced bulbs and the problem worked itself out.
also possibly try to chase wiring make sure the harness isnt grounding anywhere
