Right Blinker Problem.
GeKo
68
Nov 15, 2007
Altamont, Illinois
Iv searced and nothing seems to be close to my probelm... Here goes, when i turn the lever to use the right turn signal the nose goes "click" just once though. Their is no turning singal at all, even the green turn signal in the cluster doesnt even show up...
When i hit the hazards only the left side green light blinks and so does the left blinkers..
This is my second eclipse, and my other one had the same problem iv been through so many sites trying to find the solution.. Ending up to find nothing...
Is it the turn signal/flasher unit located behind the headunit?
When i hit the right turn signal it doesnt make the same sound as i do when i use the left turn signal.
Thanks!
i see you got a spyder. if it is the "flasher" its going to be a dealer item. mine went out/going out. my blinker flashes super fast in both directions. i knew it was the flasher, so i went to buy one. tried to put it in and come to find out its not the same. instead of being a round fuse/socketed type deal. its a box in the dash. you should be able to hear it when the blinker is on and flashing... pull the radio and turn the blinker on. if you find it anywhere other than the dealer for less than 60 bucks let me know.
yep. a bit pricey in comparison to a $7dollar flasher.
i dont know if the problem your having is the flasher for sure. but if it is now you know where it is. if you not sure, turn on a the blinker that does flash and you can actually feel it tick. Good luck.
